Inventor-2017 assembly
Hello guys,I'm facing issue in a assembly ,I have constrained the components even though it shows DOF error in DOF analysis,how can I over come it?
MSD_takaseh
Hello varun94prashanth,
Try Rebuild All and then DOF analysis again.
If you are still facing the issue then attached reproducible dataset.
Hitoshi Takase
I'm new to modeling software,I'm unaware of grounding the component,Finally i got that how to ground that,problem solved.Thank you for your reply
