Inventor 2016 Update 2 can't find internal iLogic rules and forms
BrandonBG
BrandonBG
This morning I updated Inventor 2016 to Build: 138, Release: 2016 RTM Update 2- Date: Fri 06/12/2015.
I'm running in Windows 7 Professional 64-Bit, Service Pack 1.
In DWGs, IAMs, and IPTs, the internal iLogic rules and forms are no longer there. External rules are visible.
I loaded the same DWGs, IAMs, and IPTs on my backup PC running Inventor 2016 Build: 138, Release 2016 RTM, Date: Fri 2/27/2015 and everything works fine.
Yesterday, all my rules and forms worked fine on Update 1.
Anyone else seeing this?
BrandonBG
BrandonBG
To add to the above, I uninstalled Update 2, and everything works fine again.
Brandon
david.harris
Hi Brandon,
Unfortunately the wrong file was inadvertently uploaded to the Autodesk Knowledge Network.  This is being corrected currently and I will send notice once the correct version is live on the AKN.  The Application Manager is (or will be soon) delivering the correct version.  Please uninstall Update 2 if you did download it from the AKN today and obtain the proper version from the App Mgr or wait for my notice of the correct version being available on th download page.
This should not be related to the Update showing in Install Updates.  The Update should show in both the About box and the Installed Updates list.  The list of issues addressed is not affected by this change.
Sorry for the inconvenience.
David Harris
david.harris
Hi Brandon,
The file version has been corrected on the Download site.  Please uninstall the old version and re-download Update 2 and install.
Again, sorry for any inconvienance.
Best regards,
David Harris
