Inventor 2016 SP2 slow render
Hi
I have a customer with an Inventor subscription running latest version 2016 SP2.
PC is Win10 x64, i7-4790K, 16GB RAM, Intel PCIe NVRAM SSD, Geforce 960GTX 2GB. Should be very fast, no?
NVidia driver is up-to-date.
When he creates a sketch it is extremely slow. Like a few minutes slow..., and Inventor stops responding. Sometimes it crashes.
One CPU core goes to max usage. GPU load is average.
If he deletes the render it also takes a few minutes.
Shouldn't it also be multi-core aware?
He also has Autocad & Showcase on the pc but it also happens when only Inventor is open.
I attached some screenshots.
Can someone give any advice?
best regards
David
Edited by request
Discussion_Admin
dgorsman
When you say "render" do you mean, as in generating a pretty image?  Or updating what's on screen?  Or...?
Not all parts of the program are multi-thread capable (for a number of reasons, discussed elsewhere).  Rendering, as in creating a pretty image, like most Autodesk engineering products is CPU based and multi-threaded so it will take advantage of many cores but not the video card.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
I don't know inventor myself but he tries to create a 2D sketch by clicking that first button in tab Sheet metal and it takes forever for random/complex patterns.
For example the pattern you see in the screenshot.
Daniel248
Possibly too many points on Polylines…
Looks like those curves may have been imported as a sketch from AutoCAD.
If so, the speed can be improved by re-creating the polylines with a reduced number of points and re-import it in Inventor.
