Inventor Forum
Inventor 2013 - Inventor Material Library Not Found
2 REPLIES 2
GSE_Dan_A
731 Views, 2 Replies
Can't seem to locate the Inventor Material Library....under Default in Projects, the Inventor Material Library is highlighted in Red.  Anyone know where I need to browse to inorder to locate it?
Regards.
GSE Consultants Inc.
Windsor, ON. Canada
2 REPLIES 2
GSE_Dan_A
in reply to: GSE_Dan_A
I open Inventor 2013 and am greeted with this message after accepting the Updating Appearance. I assume this is expected as the original file was created and saved in Inventor 2012.
Then when I try to apply a material and I select the silver ball I get this popping up....
Is this expected behaviour or am I missing a link to someting?
Windsor, ON. Canada
ChrisMitchell01
See attached for the default location of the Inventor material lib. Do you have this file on disk ?
Your Design Data setting for either the active project or in Application Options may also be coming in to play here. What do you have set for that ?
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
