Inventor 2012 file open dialog
In Inventor, when I go to open a file, Inventor remembers the previous fileaname and path (thats good) but I still have to drag the vertical scroll bar to get to the file. If the number of files in the directory is small, then this is a non-issue (you dont have a vert scroll bar), but if it is a large directory, then it becomes a problem.
Watch this video....http://screencast.com/t/YYmm5jeg
In this video, I first open the -19 part, then next I open the -23 part. I have to pull the scroll bar down to get to this part.
It should remember the filename, path AND highlight the filename in the window. Here is a thread about the same issue in 2011...http://forums.autodesk.com/t5/Autodesk-Inventor/File-Open-dialog/m-p/2705669/highlight/true#M378013
Will we E-V-E-R get this to function correctly?
This is in Inventor 2012, sp1. Running on Win7x64.
