Inventor 2010 Pack and go missing from windows explorer
This widget could not be displayed.
I recently installed service pack 3 for Inventor 2010 (64bit).  After the install everything works fine except for the fact that the "pack and go" option is no longer available in windows explorer or through the open file dialog box in Inventor.  I am running Windows XP but I'm not sure if that is part of the problem or not.  I am still able to successfully pack and go assemblies through and open session of Inventor through "save as"-->pack and go.  Does anyone know what the cause of this is or how to fix it?
Pick the big "I" in the upper left corner, pause on Save As until it expands, then Pack & Go is at the bottom of the column.
Is that not what you see?
