Inventor 2010 Add-in Startup keeps unchecking
michaelrestivo
michaelrestivo
I have a 2010 inventor install.  I just finished a model, and am trying to create a STL file.  Save As does not show STL file format available.  I go to add-in manager through start button (can't access through Inventor ribbon button), and check stl translator load on startup box.  Inventor not running while I do this.  I check add-in manager through start button immediately after, and load on startup button returns to unchecked for STL translator.
Replies (7)
blair
I beleive that you need to go through the File>Export>CadFormat for this and not the File>Save-As
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
Go to File>Save Copy As>
expand the list of file types
take a screen snip
attach the image here.
michaelrestivo
Blair,
Thank you for the quick response.  My export button allows only .xgl or .zgl.  The option button on the export dialog box can be pushed, but no observable action occurs.
michaelrestivo
JDMather,
Thank you for the quick response.  Here is the screen shot.....
JDMather
Can you attach the *.ipt file here?
Have you installed all Service Packs and Updates for 2010?
michaelrestivo
JDMather,
Again, thank you for responding.  I am a little retiscent to send the ipt file.  I do have access to individuals in my lab with Inventor, and will try and work with them to get the STL file.
As to the Service Packs and updates, I am not aware of ever conciously doing this.  Is there a procedure to perform, and do I need Admin rights?
Thank you!
PS-as a side note, I purchased Autocad Inventor 2015 via digital download, and have yet to figure out how to bypass our firewall to get it downloaded.  Urgh.
JDMather
Service Pack
