My students and I have run into this problem repeatedly with Inventor 2017 but not with previous versions. Here's a simple example.
I've created this sketch. I began with the center point circle and its dimension. Added the top line, tangent curve and bottom line ( make sure the lines were coincident with the circle. Then horizontally aligned the center point of the curve with that of the circle and added the tangent between the line and the circle. Lastly added the 3" dimension. Perfect, we have a nice simple sketch that is fully constrained that includes two closed loops. I even ran Sketch Doctor on it to ensure everything was fine.
The next step is then to extrude the shape.
As you can see by the color of the lines, Inventor is only finding one valid closed region. Super frustrating!
So here's the crazy part. I exit out of the extrude command without extruding anything and return to the sketch environment, remove the tangent constraint and move the lines so that they are not longer tangent to the circle, and my sketch is not fully constrained.
Now when I go to extrude the feature, I have to valid regions!?!
At this point, I symmetrically extrude the right part by 0.5"
OK, so that worked, but it still isn't shape I need. With the extrusion in place, I edit the original sketch and add the same tangent constraint that previously removed and finish the sketch.
The extrusion updates and appears as originally intended.
Clearly this is a very simple example with a simple work around, but I haven't seen the issue in the past and have worked with each release since 2009.
Is this a bug in 2017?
