I have an error message about an invalid axis/origin in a part sketch. I understand that I need to select the X or Y axis & then pick a vertex to indicate the direction but how do I do this in a circular part with no appropriate vertexes to select?
Inv2019 pro.
Solved by IgorMir. Go to Solution.
I think the forum needs a bit more information from you to help with this issue. Could you post your part and at lease give a screen capture.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
From a top of my head - I think you can redefine the axis by picking Part's Origin axis. Give it a try anyway.
Cheers,
Igor.
Inv2019 pro.
