Invalid Axis Origin on a sketch that doesn't exist!
sijcooke
Message 1 of 14
sijcooke
Hi, All please can someone help!!
I keep getting an invalid axis origin error on Sketch16.. but Sketch 16 does not exist in the part! Therefore i can not find a way to resolve the issue.
If i move the 'end of folded' thing up to just above a rectangle pattern 3 the error goes, but then if i delete the pattern it appears again!
I have attached the part in question!
Thank you for any help given!
Simon
Replies (13)
Message 2 of 14
Curtis_Waguespack
Hi sijcooke,
I think this part is corrupt. I deleted all of your features, so that there was a empty feature tree, then saved, closed and reopened the file, and it prompted me to resolve these file links:
  • END_END.ipt
  • END_BACKTOP.ipt
  • MAIN_ASSEMBLY_NOEDIT_VARS.ipt
With no features I could not see how it could be looking for those files?
I hope this helps.
Curtis
Message 3 of 14
sijcooke
Hi, Thanks for the reply.
I have had another look at this, and  i think i can shed some light on the problem! I have another part very similar to this, and this file is linked to END_END, END_BACKTOP and MAIN_ASSEMBLY_NOEDIT_VARS.
When i created the part MID_TOP, to save re-drawing it, i opened windows explorer, copied the part file and renamed it MID_TOP. I then made some slight changes to it as it is slightly different to the original i copied.
Thinking about it now, maybe copying the file in windows explorer is the wrong thing to do.. and i should probably use inventors copy tool, on the assemble tab\Pattern.
Id be interested if you think this is the best way to copy a part?
Thanks, Simon
Message 4 of 14
Curtis_Waguespack
@sijcooke wrote:
.... i should probably use inventors copy tool, on the assemble tab\Pattern.
Hi sijcooke,
I think doing a Save As from within in Inventor would work just as well.
I hope this helps.
Curtis
Message 5 of 14
sijcooke
Thanks for the reply... yes that probably would work ok, i'll give it a go.
Many thanks, Sijcooke
Message 6 of 14
n.schotten
Hi. I know this is a reasonably old post. But i have a scimilar problem with 2 files.
Background:
I did a copy design. Made a 2nd instance of a part and did a save& replace on it. The part still had some bolted connection holes on it from the original part. I deleted those holes and was left with several green center marks that don't show up in the browser. I did an edit sketch on them, deleted the marks ended the sketch. Somewhere along the way i am now stuck with a glaring red cross telling me sketch24 has an invalid axis/origin. However sketch24 is nowhere to be found. and the solution process pops up an error that the part needs to be rebuild for editing. That seems to do something but not realy. The red cross remains and it wants to rebuild... over and over again.
How to get rid of this sketch?
Message 7 of 14
torbjorn_heglum1
The part seems to be corrupted.
I have this macro where I can manipulate all sketches found in a part, and it finds 6-7 sketches that aren't shown in the browser. Only sketch 24 seems to report an error, while sketch22 to sketch31 seems ok.  I can manipulate visibility for those sketches and I see that the sketch29-31 is owned by the 'locked' hole features. I am not familiar with these locked features, but I would suspect they are made by a bolted connection created in the assembly?
If that is the case, could it be that you had other bolted connections that later have been deleted? And that deletion maybe corrupted the part by leaving traces of those sketches?
Torbjørn
Inventor 2021
Message 8 of 14
JDMather
Can you post screen shot of errors/red cross?
I am not getting any errors on my machine with your file.
Message 9 of 14
n.schotten
Yes, the 3 locked holes are from the assembly Bolted connections.
And the faulty missing sketch probably came from a deleted BC hole.
Can your macro also remove these offending sketches?
If so, would you be so kind as to share it with us?
Niels
Message 10 of 14
torbjorn_heglum1
The sketch cannot be deleted by this macro, I am afraid that your part is corrupted. If that is the case the only way to get out of this is to re-model the part.
I am afraid I am not allowed to share this macro, as the sketch function is just a small subset of a larger macro for master modelling.
Torbjørn
Message 11 of 14
JDMather
@n.schotten wrote:
...remove these offending sketches?
Delete the Holes.
Right click Edit the sketch(es).
Delete the sketch points.
Finish sketch.
I do not get any errors?
Message 12 of 14
philip.wingate
I know this is an old thread, I had the similar issue and in inventor 2023 under manage there is a purge tool that allowed me to delete the sketches that were not showing in the tree.
Might be of use to someone else who comes across it.
Message 13 of 14
sijcooke
Thanks for the reply.. where is this purge feature?
Under Manage, i only have a Purge on the Style Library.
Im using inv 2023.
Simon
Message 14 of 14
johnsonshiue
Hi Simon,
You need to install 2023.2 update.
Many thanks!
Software Test Engineer
