Inv2012 Template Menu
CadUser46
CadUser46
Quick question.  Clicking on the QNEW button (i know its not QNEW in Inv) the template menu flashes up then disappears but it must be floating somewhere as the app is locked.  Only problem is i cant find it anywhere and it only started happening last week.  As far as i can tell its not off-screen anywhere nor shown using alt+tab.  My usual trick of using the nView manager to prevent windows opening off-screen is not working either.
I dont appear to have updates installed for a while but IT did push Secunia CSI Agent on the 29th.  No one else seems to be having a problem.
Any clues?
Cheers
Craig
Inventor 2010 Certified Professional
Currently using 2023 Pro
CadUser46
Problem solved.  I forgot i was messing with a project file that points to a template in the workspace.  Lesson learned, it does not like this.
Mark.Lancaster
Did you try the alt+spacebar, m key, right or left arrow key, and then move your mouse...
Mark Lancaster
mcgyvr
If a dialog box is offscreen (due to dual monitor setups,etc..) you can move it back with
Alt+Spacebar.. the press M.. then use arrow keys to move it back onto your screen..
