Intersection line
Intersection line
WIRMNS
Intersection line
WIRMNS
is there a way to set off intersection lines from my dimension in a drawing?
CCarreiras
Hi!
I believe that is hard coded, there's no option in styles library or when pressing right mouse button to edit that.
Anyway, try to hide extension lines in your specific case, just to check the result.
CCarreiras
WIRMNS
I had try that option and it is the same result. I had hoped there was another way to do it.
CCarreiras
Well, as this is a less used dimension, probably Autodesk developers have "forgoten" to add more options to this feature.
You can ask for this option at "Inventor forum ideas", and hope that they implement the option in future releases or updates.
Put your idea here: Inventor Ideas - Autodesk Community
CCarreiras
