Inventor Forum
Intersecting Bend Failure
2 REPLIES 2
gfunnybus
351 Views, 2 Replies
I'm trying to recreate an imported solid (possibly created in Solidworks or Pro-E) into a clean, parametric model using Inventor sheet metal environment. This part has one tricky area where two bends intersect. I've had three attempts so far using bend, flange, and fold. Fold is kind of lame, but it gets the most accurate part so far. However, Inventor rips the part at the seam, instead of blending the bends. If anyone has an idea or work-around, it would be appreciated.
Images Attached.
'Funnybus
2 REPLIES 2
A thought, try a lofted flange using your end profiles then trim the ears to shape.
Using Inventor 2022 on Windows 10
Ideas needing support: spur gear tooth profile, rack gears generator
johnsonshiue
in reply to: gfunnybus
Hi! The original part though looks nice, is actually not real representation of crossing over bends. Inventor does not like two bends crossing over each other. If you want, you can attach the part here or send it to me directly (johnson.shiue@autodesk.com), I can take a look and see if there is a way to avoid such bends.
Many thanks!
Software Test Engineer
