Intermitten Pattern
Is there a way to do an intermitten "pattern"?
I find myself time and time again wishing I could do this and I was never sure that the answer is that I can't. This was possible in SolidEdge and i thought maybe it might be in inventor.
Anyways..The idea is that a part or ob ject can be "patterned" along a curve or axis at pre-determined locations. In my example I use points constrained at various angles.
This would be more useful to me in assemblies, but the functionality within the part environment should work the same way.
Is there a way to pattern this cylinder along the arc and have it go to the specified points? or Is this something that would need added to the IdeaStation?
Is there another way to work around this without recreating the part each time? (this is a simplified example, its often more complex than this and at times requires a lot of time to recreate each instance)
Some examples attached
