Instance properties
Instance properties
dleigh2GBTW
Instance properties
dleigh2GBTW
Morning all.
I have an part that occurs twice in an assembly. In the assembly I have given each of these occurrences a "Tag No." via the Instance properties. Let say the part file is called "Valve.ipt" and the 2 Instance properties are set as "Valve 1" & "Valve 2"
Now on the drawing, I would like the parts list to show that item as 1 line (Qty 2). But the balloon will show the item number (that would be the same) and the "Tag Number". I can get he parts list correct, but the balloon shows the "Tag No." as *Varies*
Donald
Inventor 2026
SharkDesign
The balloon will show exactly what is in the parts list. You would have to use a text leader to show the different tags, or change the parts list display.
  Inventor Certified Professional
CGBenner
@dleigh2GBTW
Hi, THIS is a very old blog post I did to create a workaround for a similar problem involving showing items with the same Part Number (which would be grouped in a Parts List) but showing them as separate line items sorted by length.
Obviously this exact workflow won't work for you, but this might help you to figure out a workaround for your situation.
Did your question get successfully answered? Then just click on the 'Accept solution' button.
Let us know how we did on Trustpilot.
Thanks and Enjoy!
Chris Benner
johnsonshiue
Hi Donald,
Please share the files here. I would like to understand the ballooning behavior better.
Many thanks!
Software Test Engineer
dleigh2GBTW
Hi @johnsonshiue.
See attached as requested. The only thing I would like different is in the parts list to have the item number the same for all the items that have that same part number. If the assembly had, say, 20 valves, there would be 20 numbers in the item row.
Donald
johnsonshiue
Hi! Many thanks for sharing the files! I guess you would like to see the instance property "Tag No." be listed respectively in one cell. Unfortunately, there is no workflow to do that at the moment.
Thanks again!
dleigh2GBTW
thanks for the reply @johnsonshiue.
Looks like our workflow for now will be:
  • Not show the "Item" number in the parts list
  • In group setting or Part List:
    • First key = Part Number, all others none.
    • Second and Third key = None
    • Untick Display Group Participants
    • Tick Display Item Numbers
    • Bill of Materials in the model:
      • Part Number Row Merge Settings
        • Tick Merge Rows on Part Number Match
        • Untick Merge Instance Rows.
    • In Balloon, We show Part Number and Instance Property
Donald
