Inventor Forum
Installation view
4 REPLIES 4
Emre_Yucel
160 Views, 4 Replies
Installation view
Hello, in the old versions in the assembly, there was marking and pinning that appropriate assemblies were made, you can look at the photo, but in the 2024 version there is no this ability, I wonder if we need to adjust it somewhere, how can I edit this problem, thanks for your help, good day
4 REPLIES 4
Hi
A pin means that an element is immobilized (via a command, not a constraints).
The dot indicates the degree of freedom of the component. You can control the display of the dot in the browser menu (hamburger).
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi Kacper, I think I expressed it wrong, I was talking about the filled and empty box at the point I marked, actually
Yes, this is information about the degrees of freedom of the component.
Kacper Suchomski
k.hendrickx
in reply to: Emre_Yucel
these boxes can be turned on and off in the little hamburger button in the top right corner of the model browser
Once a component is immovable (either due to constraints or due to being grounded) the circle will be filled up.
