Inspect Dimension Not Working In Assembly
vatorhoist
vatorhoist
So this is the first time I have had this problem out of hundreds of assemblies.
When I chose inspect dimension usually I can choose any feature I want to measure but for some reason it will only select whole parts and it gives me random dimensions with no line showing what its measuring.
I can still measure things in any other part or assembly just fine and there is absolutely nothing out of the ordinary in this assembly.
I even deleted the whole file and started over but still cant choose faces, edges holes, nothing. only whole parts.
Very confused please help.
kelly.young has edited your text to lowercase for clarity
mcgyvr
@vatorhoist
Change the "priority" at the top of the measure tool..
johnsonshiue
Hi! The information you provided so far is not actionable. Please take a screen shot so forum experts can comment further.
BTW, if possible, please refrain from typing in all cap letters. It may be convenient for you but it is considered yelling at people. This is a professional forum. Please treat people professionally.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
@vatorhoist were you able to figure out what was affecting your measure tool?
The only thing I can think of was the priority like @mcgyvr mentioned.
Can you supply a screenshot or screencast as to what you are seeing?
Please select the Accept as Solution button if a post solves your issue or answers your question.
