Inserting Image Into Drawing sheet
I couldn't insert jpg image into the drawing sheet. I know how to insert into TitleBlock, but I can't do it in the sheet between the drawing. May get some help.
atajabbas
Inventor 2016
mdavis22569
Are you looking to do something like this:
Mike Davis
johnsonshiue
Hi! Like David's video shows, you will need to use Insert Object (via OLE) to place an image in a drawing. Inventor drawing generally is a vector space (precise). It has to treat non-vector data (raster) specially. There is another workflow if you need to insert the image repeatedly. You can create a Sketch Symbol (Annotate -> Define Sketch Symbol -> insert the image to sketch) with an image. Then you can insert the image symbol multiple times.
Many thanks!
Software Test Engineer
Mr.
You are very nice men
Thank you
atajabbas
Inventor 2016
mdavis22569
Not a problem ...
Have a great great day!!
Mike Davis
