Inserting Flat Pattern & Formed Part Simultaneously into IDW
harvey3ELEA
harvey3ELEA
Are there any methods for laying in a new flat pattern AND the formed part into a new IDW simultaneously?
Easy to do individually, by my BASE view dialogue box never remembers the part and it's a PITA when having to re-scroll through a long list of parts to grab the file a 2nd time for insertion of the flat pattern view.
johnsonshiue
Hi! This is quite simple to do using Sheet Format. Open (or create) any idw/dwg file with the desirable  folded view and the flat pattern view on a sheet. Right-click on the sheet in the browser -> Create Sheet Format.
Whenever you want to create both views, simply select the sheet format and select the target sheet metal part. The two views will be created.
Many thanks!
Software Test Engineer
harvey3ELEA
That works rather nicely!
Been using Inventor since 2004 and never took the time to notice that handy tool.
Thanks, Johnson!
