Inserting a Ball Bearing
I'm trying to add a bearing in inventor from content center, but I can't seem to find the correct size in content center. The bearing I want to use on my physical project has a 1/2ID and a 1.375OD (link below). I've searched content center multiple ways, but can't find a bearing with this size. Is this because that bearing is a non-standard size, or is there a different content center library that I can download with this size? Is there any way to create a custom bearing out of content center?
Link to my bearing: http://www.homedepot.com/p/Martin-Wheel-1-2-in-Industrial-Ball-Bearings-2-Pack-IBB-12-NHYD/205716425
blair
The attached document will help.
For just a single bearing, I would quickly model one up that has the same mass as your sample rather than going through creating/modifying with CC.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mcgyvr
The content center is far from "all inclusive"..
And yes you can add stuff to it..
Lots of info on that process..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
https://www.youtube.com/watch?v=dg61Kw-bskA
and more
