Insert Object Issues
rttechno
rttechno
I'm having issues inserting images into idws.  I pick "Insert Object" from the "Manage" tab.  From there I select "Create from File" and select my image file.  When I click "OK" sometimes it lets me place the image and sometimes it fails without error and I have to do it again.  Anyone else encountered this or have a solution?  I don't know how to reproduce it every time but it seems to fail at least 50% of the time for me.  If I follow the same proceedure a few times eventually it just works..
Randy
andrewdroth
Try this, open the image in a viewer, copy.
Then in the IDW go to the Tools tab, and click the dropdown triangle beside Paste, select Paste Special.
You should be able to drop it in using that.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
rttechno
Thanks Andrew.  So far that method seems to be working!
