Insert Image in a Sketch
lkirit2000
Advisor Advisor
lkirit2000
Hi Team,
I am trying to insert manually using sketch and insert image, The image feature is not active . Why ???
Please see the attached image.
salih_kapucu
hi,
manage -> insert object
I took a screenshot for you. You can do it by looking at this.
James_Willo
Hi, yes this is a little confusing.
Try going to the manage tab and clicking insert object.
James W
Inventor UX Designer
johnsonshiue
Hi! In the drawing, inserting an image is only enabled in title block and sketch symbol. Inserting via Manage -> Insert is the OLE workflow. You may insert any document to a drawing.
Many thanks!
Software Test Engineer
