Insert frame 2016 problem
Hello, I have another problem with the insert frame tool in inventor 2016 student version.
When I want to make a frame, I created a 2D sketch in a part, saved it and placed it in an assembly. But when i choose all the lines. choose square tube and press apply and ok, 1 square tube is flashing in the screen and nothing else happens... I attached a few photos.
Schermafdruk 2017-03-13 10.54.19.pngSchermafdruk 2017-03-13 10.54.41.pngSchermafdruk 2017-03-13 10.54.50.pngSchermafdruk 2017-03-13 10.54.58.png
Rob67ert
Hoi Pieterjan,
The pictures are not really good to see.
Can you port your ipt and iam file?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
here they are.
kennyj
Looking at your last picture, it looks like you have your parts set to offset very far away (~3200, and ~234,234) from the lines.  Zoom extents and see if your parts aren't showing up way out in space.  Set your offsets to be 0 for all three fields and see if they show up then.
Hope this helps,
Kenny
Ah, that helped alot! Smiley LOL
Thanks!
kennyj
@Anonymous,
Did this solve your issue?  Please mark as a solution if it did.
Were you able to get your frame in place?  Post a finished image, too!
Best of luck on your project,
Kenny
