Insert constraint locks part
jrapert
Message 1 of 12
jrapert
Insert constraint locks up part and not possible to rotate even the Degrees of Freedom shows free rotation.
Screenshot attached
Inventor 2023 Pro
Windows 10 - 64
32 GB RAM
Replies (11)
Message 2 of 12
James_Willo
Your browser icon should show a lock if it's locked, therefore my only other thought is that you are on 2023?
There is a known bug where adding constraints can stop parts from being dragged.
It will be fixed in the next update which is coming soon.
James W
Inventor UX Designer
Message 3 of 12
kristin.jakuszanek
I am running inventor 2022.2.2 and have an issue where my parts will also stop dragging when enough constraints have been added.
If I can get the issue to occur today, I will post a follow up video.
Message 4 of 12
johnsonshiue
Hi! The behavior does not sound right to me. Please install 2022.3 update and report back your findings.
Many thanks!
Software Test Engineer
Message 5 of 12
kristin.jakuszanek
@johnsonshiue
I have this now installed and was messing around in an assembly I knew I was having issues with the locking up and it doesn't seem to be continuing to happen. If I see this behavior going on on another assembly in the next few days I will get a recording of it.
Message 6 of 12
johnsonshiue
Hi Kristin,
Based on your description, it sounds like you may have pre-existing sick constraints. If yes, you may want to fix them or delete them. When sick constraints are present, Inventor will try to solve the constraints system more elaborately as an attempt to resolve the errors.
Another possibility is that you may have extensive usage of Adaptive components. When a component is adaptive, its DOF is reduced and it is piggy-backed to the driving component.
Yet another possibility is tangent constraint. As an attempt to stabilize constraint solve, the tangent constraint participants may also have reduced DOF. You may want to use Cylindrical Face Mate or other equivalent constraints instead, when the participants have other constraints attached to them.
Please feel free to share an example that exhibits the behavior. Forum experts can help take a further look.
Many thanks!
Message 7 of 12
kristin.jakuszanek
Johnson,
I know this wasn't an issue of sick constraints because it was occurring after my update from 2020 software to the 2022, on assemblies that weren't having this issue in 2020. It was mostly happening with cylindrical components. There would be no red plus sign or errors when checking via CTRL+f7, but deleting a constraint, or adding an additional component would usually free up the stuck components.
It can't be adaptive components, as we don't utilize them, and there were none in the assembly that was causing me the initial issues.
In this assembly there were two components utilizing the tangency mate (cylindrical object to flat surface so the cylinder is laying on the flat surface), but I would hope that only two of these mates wouldn't give an issue such as what I was experiencing, as this mate wasn't an issue in 2020.
As previously stated, I installed the latest update and the assembly that was giving me these issues, is no longer doing this, so I am guessing the update fixed something that was being buggy on my end. If I do see this happening again, however, I will get documentation of this and post here.
Cheers!
Message 8 of 12
kristin.jakuszanek
Johnson,
A follow up to this issue. I have a subassembly with no constraints that will not move by dragging. I can drag other components freely, but not this one subassembly. The subassembly was made using the demote command. I can move it using the free move tool, but it will always stay where it is put once it is moved. I can also constrain it and it will pop the constraint into place when I accept it, but the part wont move before that even though the 'show preview' box is ticked on the constraints option. I have checked the bodies and there are no bad bodies showing, and no errors are present on the assembly. I have tried closing out inventor and opening the assembly back up and the subassembly still doesn't freely drag around.
body check for assemblybody check for assembly
Message 9 of 12
johnsonshiue
Hi Kristin,
It is probably due to adaptive. Right-click on the adaptive sub -> uncheck Adaptive. Does it move now?
You need to ground a logical component (which does not move). Please feel free to share you files here. Forum experts and I can take a closer look.
Many thanks!
Message 10 of 12
russell.lowe3
I had the same thing happen today ... it turns out it was due to using "pattern components". I had several instances of patterned components and if I deleted them all, or suppressed them all, the other components and constraints would behave as expected.
There were no warnings or indication anything was wrong with the patterns.
Hope this helps anyone finding this thread.
Cheers
Message 11 of 12
JDMather
@russell.lowe3
Have you installed all Updates?
Message 12 of 12
johnsonshiue
Hi Russell,
I believe you are on 2023 RTM version. Please install 2023.3.1 update. It should fix the issue.
Many thanks!
