Hello Inventor Forum,
This is a question about Inventor Ilogic. I have an assembly with 5 parts that are all the same except for a difference in height. The part names are "Part: 1", "Part: 2", Part: 3" etc. The height parameters are "PartHeight1", "PartHeight2", "PartHeight3" etc. I also have a parameter "NumberOfParts" which dictates how many of the parts are present in the assembly.
I want to write a for loop such that:
for i in range(0, NumberOfParts):
PartHeight[i] = InputBox("What is the Height of Part" + str(i), "Part Height")
end for loop
I could also do the same thing with a while loop:
i = 0
while i<NumberOfParts
i=i+1
end While
My question is: How do I index the parameter name "PartHeight1", "PartHeight2", "PartHeight3" etc. during the loop? It throws a syntax error if I do something like ("PartHeight"+str(i)) = InputBox(....). Is there a way to index through the names?
I would rather not hard code in the numbers, because the number of parts in the assembly can increase beyond the point of convenient hard coding.
Thank you!
Nicholas
