Increase font size for Edit Dimension box/window?
Zweerink
Zweerink
I teach a high school computer aided drafting class, and when I'm showing them on the projector how to make a sketch and what numbers I want them to enter the font is too small for them to read while I'm typing in the Edit Dimension box.  Is there a way to make the font size bigger for that?
I went to file>options>General>Text appearance and changed it from 8 to 9 point, but  it made no difference.  Searching indicates that I can use the annotation scale for my dimension text, and that worked great, but I sure would like to make that text entry box a little bigger.
leowarren34
Hi @Zweerink,
I don't believe it's possible if you're referring to this: https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t...
I can double-check with @johnsonshiue but I think the best bet will be to increase your annotation scale (Application Options -> General Tab)  so your students can see the dimension once placed
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
johnsonshiue
Hi! To change the sketch dimension display size, you can change the Annotation Scale (Tools -> App Options -> General -> Annotation Scale -> change it to 3 from the default value 1.0.
Regarding the dialog size, you will need to change the DPI (%) in Windows Display settings.
Many thanks!
Software Test Engineer
I had questioned the same component at one time. I made most of these task parameters after which descovered Shared Parameters and desired to transform all of them to a Shard Parameter record as you canread.
