sorry Jeff, guess I should have refreshed sooner...hour and a half (wow, I'm
getting slow..)
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Sean Dotson" wrote in message
news:0DBB8E096F2E6E8B5C5475107C00A198@in.WebX.maYIadrTaRb...
> A few ways to skin the cat but one way is to use the isolate function:
> isolate(d1:ul:in) assuming that d1 is in units of inches
> another is
> d1/ in (again assuming that d1 is in inches)
> when you use mixed units (ul and in) you get into all sorts of hairy
> problems...
> BTW ul stands for unitless
> for more info download the tutorial "Introduction to Inventor Functions"
on
> my site
> Sean Dotson, PE
> "scott peebles" wrote in message
> news:2DF5B03CB31D6C56EBCA2218962CBA0A@in.WebX.maYIadrTaRb...
> > I am trying to insert a parameter name (d1) into the equation field of
> > another parameter (d13).
> > The value (d1) is showing up 2.54 times larger when inserted into this
> > equation field.
> > This parameter (d13) has a "ul" unit designation. Is this "ul"
> designation
> > causing the problem? Why are parameters being multiplied be 2.54 when
> > inserted into the equation??
> > Thanks
> > Scott
