Incompatible Units Error
mpatchus
Advisor Advisor
Message 1 of 9
mpatchus
I think I know why this is occurring, just not sure how to resolve or work around.
Scenario:
  • We have an assembly of parts used to mount a light fixture.
  • This assembly includes the fixture, bulb, mounting bracket, hardware, conduit and fittings.
  • We have given this assembly a specific PART NUMBER and STOCK NUMBER which are used in our ERP software, and is ordered as a single item.
  • The assembly can be installed in two configurations, right hand or left hand.
  • A derived part for each configuration was created from the assembly, with the PART NUMBER and STOCK NUMBER identical in each part. (LH version being mirrored about one of the planes.)
Issue:
  • Parts list acts normal until merged by PART NUMBER.
  • When an installation requires both versions of the assembly, we get an INCOMPAITBLE UNITS error in the Parts List when merged.
I'm guessing that Inventor sees these derived parts as two separate items even though they have the same PART NUMBER & STOCK NUMBER, thus throws the INCOMPATIBLE UNTIS error.
Any suggestions, tips or work arounds would be appreciated as we have several assemblies like this that can be put together in multiple configurations using the identical parts.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Replies (8)
Message 2 of 9
andrewiv
Does this post fix your problem?
https://forums.autodesk.com/t5/inventor-forum/incompatible-units-error-w-each-set-in-part/td-p/85743...
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 9
johnsonshiue
Hi! Please follow the posting Andrew mentioned. If it still does not work, please share the files here.
Many thanks!
Software Test Engineer
Message 4 of 9
mpatchus
Does not address the situation I have described.
Inventor 2025 Beta
Message 5 of 9
mpatchus
@johnsonshiue no need to share any files, I can replicate the results using a bolt nut and washer from Content Center.
Put together as described in initial post, 3 identical parts assembled in two different configurations.
Same result.
Inventor 2025 Beta
Message 6 of 9
andrewiv
Can you share the files, or do a screencast showing how to get this?  I cannot seem to duplicate the problem on my machine.
Andrew In’t Veld
Message 7 of 9
mpatchus
'll have to duplicate it from home later.  Unable to share files at work due to restrictions.
Inventor 2025 Beta
Message 8 of 9
johnsonshiue
Hi! I cannot reproduce it on my machine. As long as Base units are the same, the quantity should be computed correctly. Incompatible errors only appear when the two Base units are different. I need to see an example if it behaves otherwise. Check Doc Settings -> BOM -> Base Unit for each part and make sure they have the same unit.
Please send the files to me directly johnson.shiue@autodesk.com.
Many thanks!
Message 9 of 9
CGBenner
@mpatchus
Hi, were you able to resolve this, or do you still need some assistance.  If you found a solution can you please share or mark a response as Accepted Solution?  Thank you!
Chris Benner
