Include the vertices in a 3D Sketch?
Message 1 of 9
Hi
   How do I include the vertices in a 3D sketch? I need to view the vertices for project geometry on another sketch plane? I right clicked the 3D Sketch and it says Dimensions Visiblity but its not showing
Replies (8)
Message 2 of 9
CCarreiras
Place the part here...
CCarreiras
Message 3 of 9
If you right click the sketch there is an option called 'polygon visibility' - this will show the vertexes.
Message 4 of 9
both the 2D and 3D Sketch have  a tick next to it saying it is visible abut not yet visible
Message 5 of 9
The ipt file?
Message 6 of 9
Here is the part
Message 7 of 9
Right click Sketch1 in the browser to the left, select 'display dimensions'
Then right click 3D sketch1 in the browser and edit sketch, then use the dimension tool and select the yellow referenced lines to create referenced dimensions.
Message 8 of 9
and where are the vertices in the file you sent? I am only seeing basic dimensions
Message 9 of 9
It may be easiest just to recreate them on the 3D sketch.
