Welcome! What version of Inventor are you using for this? (always a good idea to share this in a post)
Can you share the JT file here? If so, just attach it to your reply.
Did your question get successfully answered? Then just click on the 'Accept solution' button. Thanks and Enjoy!
Chris Benner
Use Navisworks to open and verify the JT file if you can. See if you have any other readers to open this and test that it is not empty.
Did you select all object filters to import? Most likely the data would come in as a mesh.
Thank you, it was meshes I knew it had to be simple. I appreciate your help.
I have all selected and still am seeing nothing. This is all *.jt files I'm trying to open.
Hi Joshua,
A quick test to try. Upload the jt file to viewer.autodesk.com. Does it work? If it does, it will be an Inventor bug. If the viewer cannot display anything in the jt file, it is likely a limitation in our JT translator or there is a problem with the JT file itself. Also try using JT2GO to see if the file can be viewed properly.
Many thanks!
Hi Joshua,
Many thanks!
