Inventor Forum
Importing application options doesn't actually update them
4 REPLIES 4
snappyjazz
196 Views, 4 Replies
I have exported my application options to share with another cad user. Things like Content Center Access Options(to Vault Server), and iFeature user root directory. However when I import these options on the other computer, they don't get updated. I get the below dialogs when I click "apply" after importing. I've restarted Inventor after importing, but I still don't have updated Application Options. Am I doing something wrong or is there a problem here?
One of the settings I want to change:
Labels (2)
4 REPLIES 4
pcrawley
in reply to: snappyjazz
I think you need to switch Projects rather than restart Inventor.
Import the Application Options - Go to Projects - switch to a different Project - switch back to current Project - Check App Options.
Peter
snappyjazz
in reply to: pcrawley
@pcrawley Thanks for replying. Unfortunately that didn't work. Does that work for you? I'm using 2022. What version are you using?
pcrawley
Hi @snappyjazz - sorry for the late reply.  It does work for me, but I'm using 2023 and 2024.
If importing the settings doesn't work, then it is probably related to the user's permissions in Windows.  Application options are stored in the registry, and the user may have insufficient permission to write the changes.
Try right-clicking the Inventor icon and using "Run as administrator" - import the settings - restart Inventor (again using "Run as administrator") and see if the changes remained.  If they did, then the problem is the user's permissions.
Peter
snappyjazz
@pcrawley I ran inventor as admin like you said and I still couldn't update as intended. But something that you said gave me an epiphany. When you said "stored in registry", I remembered that Inventor is finicky about where info is accessed from. Long story short, I moved my exported xml to the default location: C:/users/.../AppData/AutoDesk/Inventor 20XX/Preferences. When I imported from there, the application options updated!
Technology Administrators
