Inventor Forum
Importing a STP or Parasolid into Inventor 2017
10 REPLIES 10
Message 1 of 11
jesscadd
3049 Views, 10 Replies
I have an assembly that I create a shrinkwrap from. Then I export the shrinkwrap to a STP as well as a Parasolid. There are no errors or anything at this step. Both exported files are approximately 13Megs. When I try to import back into inventor to verify the files, it literally just sits there at 95%. I have tried opening a part and then do the import command. I have tried to open the file from file open command. I have tried to import into an assembly. They all hang at the same point. I even tried to just export from the assembly file, bypassing the shrinkwrap and still the same result. Am I missing a setting or something? When I did this in the past it worked flawlessly.
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: jesscadd
Both files open fine here (2017).
Message 3 of 11
jesscadd
in reply to: JDMather
Any ideas on why my system just hangs up on them when trying to open?
Message 4 of 11
JDMather
Try a simple cube first.
If that works, then try a simple assembly with one cube and one cylinder.
If neither of these test work - then we have narrowed down the problem.
Message 5 of 11
jesscadd
Created cube, saved, exported. Opened stp file no issues.
Created cylinder, created assembly with cylinder & cube, exported. Opened stp file no issues.
Next suggestion.
Kirk L. Jess
Sr. Mechanical Design Engineer
480-515-1110 x116
dse
technology in motion
17491 North 93rd Street
Scottsdale, AZ 85255
An ISO9001:2008 / AS9100C Registered Company
Message 6 of 11
JDMather
Can you post screen shot of your Import Options?
Are you opening the file from a different folder location than the original files?
Also, by chance I rebooted my computer and on the attempt after rebooting the file opened significantly faster. (I would guess less than 15 seconds vs 1.5 minutes.)
Message 7 of 11
jesscadd
Different directory.
[cid:image003.png@01D1D153.2CD25E50]
Kirk L. Jess
480-515-1110 x116
dse
Message 8 of 11
JDMather
Have you installed Update Hotfix 1?
Message 9 of 11
jesscadd
Where would I find that? When I run the Autodesk desktop App, it says there are no updates available.
Kirk L. Jess
480-515-1110 x116
dse
Message 10 of 11
JDMather
@jesscadd wrote:
Where How would I find that?
Google.
Message 11 of 11
jesscadd
Looks like I had some paths going to the server, this was causing the bottleneck. Once I adjusted file paths to be local on the machine, opened up real quick.
