importing a locally created idcl into a Vault Library
G60Dub
G60Dub
Probably a simple answer to the above but for the life of me I cannot remember if this is possible or how to go about it as its 3 or so years since having to do any content center authoring.
The situation is convoluted but hopefully the solution isn't:
We use Vault but somewhere along the line (prior to me being employed) desktop content was specified during an upgrade and now the read-only default Content Center Stuff is stored locally while Vault is used to store designs.   I'll need to push this back to the Stock Content Libraries being stored on the Vault during or prior to our next migration.
Anyway I had to create new Content and I've authored/created it in an *idcl format and hence how do I go about importing the created Library into an ADMS Library?
I'm hoping the solution is relatively simple.
CGBenner
@G60Dub
Try the Library Transfer Wizard, on your Project Editor. It's under the Configure Libraries.  Select the library you want, and the pick the Transfer Wizard.  You can go Vault to Local, or vice versa.
Chris Benner
G60Dub
Shoot! Of course (looks for facepalm emojii) Many thanks. 🙂
