I imported a step file of an assembly and although all parts are present in the Browser, nothing is visible in the Graphics Window. In the Import window, convert model, solids, surfaces and wires were all checked. In the opened file, everything is checked visible in the right-click menu, and nothing is checked transparent. When I open one of the parts in the assembly, I can see the wire frame, but can't make the part solid. In the iproperties, the material is generic, and changing it to steel doesn't help. If I promote the wires in the construction group, the wires become darker in the opened part and the wires for the part do appear in the assembly, but still not solid. I hope someone can tell me what button to push to make it all better. I work with step files frequently and haven't had this problem before.
I have attached a screen shot and one of the part files. I can't share the assembly without getting permission from the owner.
Thank you in advance.
Bill
