Imported .igs files is not visible on .idw
I have imported an .igs and would like to use it on my assembly.
Step that I created.
1. DL an igs files, then open it in Inventor 2012 Product Suite.
2. Save as .ipt,
3. Create a new .ipt and then DERIVED the save .ipt, change scale to 25.4
4. Save the part
5. Open .idw and place the part you just save.
Result: Notice that nothing is visible. WHY?
I have attached the said file.
sam_m
the iges is being imported as a surface, not a solid.  (well, technically it's coming in as 4 small solid disks, near the feet, and 1 surface) and surfaces aren't visible in idws by default.
Either you need to repair the surface and turn it into a solid or leave it as a surface and enable the surface-visibility in the idw (expand the part and "surface bodies," then right-click and select "visible" - as my attached image):
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
sam_m
Thank you.
