03:17 PM
Good day. It seems that my imported file settings have gone wonky last week, and I can't seem to fix them. We typically try to save all work on our file servers, rather than on the desktop so that they can be accessed from any computer. When working with imported components my work flow is typically this. 1. Download the component in step format (i found that step files import with fewest errors) 2. Copy downloaded from from downloads folder to clipboard 3. Select place from the assemble ribbon 4. Change the file selection dialog to display all files. 5. paste the downloaded file from the clipboard direction into the file open dialog, which places it into my working folder. 6. place files in assembly and work with them as needed. This worked fine in the past, save for the IPT version of the downloaded file would be placed in WORKINGFOLDER/Imported components/component file name/component filename.ipt. The extra folders weren't helpful, but they too much of a bother. However, sometime last week the IPT of the imported components started getting saved in C:\Users\%username\Documents\Inventor. This is a pretty big problem, since now my assemblies can only be opened on my computer an nowhere else. The only way I found to get around it is to edit the component in question, select save copy as, select working folder, finish edit, select component>replace all, select component in working folder. This is a time consuming task and pointless task. Is there a way to modify these settings?
