Inventor Forum
Important info for NVSTRAP/RIVERTUNER Users.
13 REPLIES 13
Message 1 of 14
399 Views, 13 Replies
After some much needed help from Unwinder here is how you can run the newer
(than 30.30) nvidia drivers with rivertuner.
UNINSTALL NVSTRAP DRIVER FIRST!!!
Reboot
UNINSTALL NVIDIA 30.30 (Windows Add/remove programs)
Reboot
Run the Detonator 30.xx to 40.41 fix (Can be found at www.guru3d.com nvidia
files)
Reboot
Install the new driver (I used 41.03)
Reboot
look in the rivatuner folder there is a tree like this
Rivatuner\Patchscripts\NVSTRAP Antiprotection\NVStarp Antiprotection w2k.rts
run this file
click the comtinue button then browse to winnt\system32\drivers and select
the nv4_mini.sys file and run the script. (this removes the anti NVStrap
from the driver)
Now reinstall the NVStrap driver as usuall and reboot and you should be away
laughing....
Brian
13 REPLIES 13
Message 2 of 14
jmartzig
brian, did you get any better performance out of this driver? perhaps IV6 isn't so sluggish....hopefully? -Joe
Message 3 of 14
loop29
I don´t think that sluggishness comes from the viewport performance of Inventor, what I noticed is that it really kicks your CPU´s bud if you have great amount of parts in an assembly. Even if I only try to move and rotate assembly it starts to compute, that should not happen while that´s the job of the video card. So my guess is that it won´t effect the mentioned sluggishness that you noticed !!
regards
Message 4 of 14
Brian, I have been trying to do this and I cannot get it to work. I think I
am doing it wrong because I cannot find the "Detonator 30.xx to 40.41 fix"
and I get an error when I try to apply softquadro. Can you describe what
nvstrap is and what I need to do to make my geforce 2 gts into a quadro?
Jeremiah
"Brian Corbin" wrote in message
news:4C06BD43D17AD90B0AED341C7FE983AA@in.WebX.maYIadrTaRb...
newer
> Reboot
> Reboot
nvidia
> files)
> Reboot
> Reboot
w2k.rts
> run this file
> from the driver)
away
> laughing....
> Brian
Message 5 of 14
*** Must be running Win2K - WinXP
***Download and install the detonator driver version 41.03*** from
www.guru3d.com
*** Reboot***
Download Rivatuner from www.guru3d.com
w2k.rts
run this file
from the driver)
run rivatuner.exe
Click on the little button on the first page besdie the word customise
Click on customise low level settings
Click on NVSTRAP driver (if not there I had to reboot a couple of times
Click install nvstrap
Force quadro features on
***reboot***
Your card should now be recognised as a quadro, and the speed is much
better...
After installing NVSTRAP. The big thing to check is if you
open a Inventor window then goto tools, app options, hardware, diag INV also
should see your card as a Quadro now not a geforce
You can never reboot to many times 😉
"Jeremiah Schutte" wrote in message
news:5A6F598834A8029086AE8DB452E3B7DA@in.WebX.maYIadrTaRb...
I
> Thanks,
> Jeremiah
> newer
> > Reboot
> > Reboot
> nvidia
> > files)
> > Reboot
> > Reboot
> w2k.rts
> > run this file
select
> > from the driver)
> away
> > laughing....
> > Brian
Message 6 of 14
ArtC
Will this work on gforce 4 cards.
Message 7 of 14
It will make your GF4 show as a Quadro4 to some
degree but it will not make any difference to any type of performance. So in
short NO it will not work for a GF4.
Brian
Will
Message 8 of 14
ltspd
Brian,
Will this do any good for old Elsa Gloria II's? I think these are Plain Quadro's?
Paul
Message 9 of 14
jorgen
It can help overclock it, but not much more
Message 10 of 14
Thanks Brian, I did that and it sorta works. Windows sees it as a quadro 2
pro, and it feels faster, but inventor still thinks it is a geforce 2 gts.
I am happy that it is faster, but I don't know why inventor does not
recognize is as a quadro.
news:C3578B13A3C1F5D34FAB39A1C2D16237@in.WebX.maYIadrTaRb...
> www.guru3d.com
> *** Reboot***
> w2k.rts
> run this file
> from the driver)
> run rivatuner.exe
> ***reboot***
> better...
also
think
> I
fix"
what
> > Thanks,
> > Jeremiah
> > newer
> > > Reboot
> > > Reboot
> > nvidia
> > > files)
> > > Reboot
> > > Reboot
> > w2k.rts
> > > run this file
> select
NVStrap
> > > from the driver)
be
> > away
> > > laughing....
> > > Brian
Message 11 of 14
loop29
Inventor should see it as a quadro too, otherwise I guess you screwed something up. Go to the advanced settings for display properties, click on graphics card and check in OpenGL properties if you can choose between settings for different professional applications, should be ACAD, 3dsmax, Microstation and so on. If there is no list something went wrong. You can search the web for GLinfo tool that will post correct openGL renderer if Inventor is doing something wrong. For basic setup, one should install drivers first than install nvstrap reboot and reinstall drivers, during boot of windows it should come up with " new video adapter found", after this patching the nv4_mini.sys in %Windir%\system32\drivers\ and reboot again. You´re done !
regards
Message 12 of 14
Dude,
Something went wrong...I would guess that the install of the anti protection
script did not work go over this again. INV WILL see it as a quadro when it
is done right. Let me know if you still cant get it to work...
Brian
news:140D6810A49EF916E7C07D8C376E64CD@in.WebX.maYIadrTaRb...
2
> > www.guru3d.com
> > *** Reboot***
> > w2k.rts
> > run this file
select
> > from the driver)
> > run rivatuner.exe
> > ***reboot***
> > better...
> also
> think
> > I
> fix"
> what
quadro?
> > > Thanks,
> > > Jeremiah
the
> > > newer
> > > > Reboot
> > > > Reboot
> > > nvidia
> > > > files)
> > > > Reboot
> > > > Reboot
> > > w2k.rts
> > > > run this file
> > select
> NVStrap
> > > > from the driver)
> be
> > > away
> > > > laughing....
> > > > Brian
Message 13 of 14
I reran the anti protection script and now Inventor detected it properly.
Thanks for the help!
news:755EDE9E7CDE707B99D4ECFE3522BB0F@in.WebX.maYIadrTaRb...
> Dude,
protection
it
> Brian
quadro
> 2
gts.
> > > www.guru3d.com
> > > *** Reboot***
> > > w2k.rts
> > > run this file
> select
NVStrap
> > > from the driver)
> > > run rivatuner.exe
times
> > > ***reboot***
> > > better...
INV
> > also
> > think
> > > I
40.41
> > fix"
> > what
> quadro?
> > > > Thanks,
> > > > Jeremiah
> the
> > > > newer
> > > > > Reboot
> > > > > Reboot
www.guru3d.com
> > > > nvidia
> > > > > files)
> > > > > Reboot
> > > > > Reboot
Antiprotection
> > > > w2k.rts
> > > > > run this file
and
> > > select
> > NVStrap
> > > > > from the driver)
should
> > be
> > > > away
> > > > > laughing....
> > > > > Brian
Message 14 of 14
Glad It worked for ya!
news:120D26D88F9720A4B11E0B7630FA255F@in.WebX.maYIadrTaRb...
> > Dude,
> protection
> it
> > Brian
> quadro
> > 2
> gts.
> > > > www.guru3d.com
> > > > *** Reboot***
Antiprotection
> > > > w2k.rts
> > > > run this file
> > select
> NVStrap
> > > > from the driver)
> > > > run rivatuner.exe
customise
> times
> > > > ***reboot***
much
> > > > better...
> INV
> > > also
I
> > > think
> > > > I
> 40.41
> > > fix"
describe
> > > what
> > quadro?
> > > > > Thanks,
> > > > > Jeremiah
run
> > the
> > > > > newer
> > > > > > Reboot
> > > > > > Reboot
> www.guru3d.com
> > > > > nvidia
> > > > > > files)
> > > > > > Reboot
> > > > > > Reboot
> Antiprotection
> > > > > w2k.rts
> > > > > > run this file
> and
> > > > select
> > > NVStrap
> > > > > > from the driver)
> should
> > > be
> > > > > away
> > > > > > laughing....
> > > > > > Brian
