Import stp files
Import stp files
Import stp files
please somebody for help. I get stp file of helmet which I open in Inventor.
When I make part which I wont to extrude to helmet I can't because there no body only like mesh on surface.
I attach file.
Please help it urgent
JDMather
What version of Inventor are you using?  2017? 2010? 10?
Do you have a green checkmark in the browser indicating the geometry has passed Inventor Quality Check?
Do you have a Solid Bodies (1) folder in the browser or do you have a Surface Bodies (1) folder?
Can you attach your Inventor *.ipt part file here?
I use ver 2015. I attach file
JDMather
I don't see any sketches in the file you attached to Extrude?
Try this file. (see attached)
I try its same. Please see attached file. In assembly I insert your helmet. Make new part, simple rectangle then extrude to helmet nothing I can extrude to point on body surface.
JDMather
1. You did not attach Inventor files again.
2. Why are you doing this in assembly rather than as multi-body solid.  (it can be done at assembly - but that requires a higher level of training)
3.  Well, I forgot what 3 was - but anyhow, attach your Inventor files here rather than image files and you might explain a bit about your design intent.
Thanks for help. I will try tomorrow again, it late I my go to bad
