Import and use DFX or DWG format 2D sketch geometry with Inventor part
I, ve to import DFX or DWG 2D sketch formats generated by an external online spur gear generator with these settings:
in Inventor 2019 to extrude gears. Because I've difficulty generating gears with the Inventor generator, which is described in my previous post "Generate spur gears 3:1 ratio with setting pitch diameter and number of teeth".
When I loaded DFX the first time it opened, but impossible to copy selected lines with an edit of the sketch to the new part sketch, and with the next import attempt, the DFX and DWG appear blank.
I've followed How to import DXF generated by Eagle to Inventor and Importing DXF files to Inventor as well as To Open or Import AutoCAD DWG Files as an AnyCAD Reference Model but it is empty. Here is the Import Destination Option, I've tried different settings, but can't import and use the attached files (2 versions of gear in DWG and DFX):
The only way I have imported DWG is by creating a new part, selecting the XZ plane with adding the sketch, and File > Open > Open DWG, copying growing curve lines and pasting to sketch, but this way the scale of the sketch is different, instead of ⌀ 14 mm I got ⌀ 1167 mm diameter
