Hello all,
This is my workflow:
- I have a part (ipt) open and click Import (3D Model / Create)
- In the Import dialog box I select <browse to a file in Vault>, see attached
- I select the autocad file from Vault and switch in the Options for Import selection, see attached
- After I click OK to end the <File Open Options> dialog box the Import selection is not remembered; I know that because I open it again and defaults to Open selection.
- I click on <Open> and it opens the file instead of creating a link to the autocad file. Everything works fine if I Import and select the autocad file from my local space (not Vault)
I hope I am missing something and it's not a bug...
I'm using 2018 and 2019, same story.
Thank you for your help.
radu
kelly.young has embedded your images for clarity.
