iLogic to delete a particular constraint
Is there any syntax that uses iLogic to delete two particular constriants? I already looked through the threads and I see that its possible to fix constraints and delete certain types of constraints. Thanks
ASchlaack
Would supressing the contrait work just as well? I could help you do that.
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Curtis_Waguespack
Hi dtowngurl51,
Here is a quick iLogic example that deletes two assembly constraints by name.
I hope this helps.
Curtis
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Iterate through all of the constraints in this assembly
Dim oConstraint As AssemblyConstraint
For Each oConstraint In oAsmCompDef.Constraints
If oConstraint.Name = "Mate:2" Then
oConstraint.Delete
ElseIf oConstraint.Name = "Insert:1" Then
oConstraint.Delete
Else
End If
Next
This works! Thank you so much! I have been trying to find code to do this for a few weeks now. I tried writing my own but it always returned an error. Thank you again!
