iLogic to close/hide an open form
Message 1 of 10
Hi!
I'm wondering if there is a way to either close or hide an open form with iLogic? Something like the opposite of iLogicForm.Show.
 / Peter
Replies (9)
Message 2 of 10
mrattray
The VBA method for closing a form is .Hide, but this seems to not work in iLogic. This is a good example of why we need an object browser for iLogic.
Mike (not Matt) Rattray
Message 3 of 10
Hope you have got answer for the same. Just answering, so that some one can use this method.
There is no direct method to hide form by ilogic as said by Mr.Mike. Behalf of that you can use the rule as button to hide the form by choosing option "Close and Run the rule"
and in that rule you can trigger show form
Message 4 of 10
JorisSteurs1246
 @Anonymous   I'm trying to find this  "on click action" in my form builder, because I want to close my form before the ilogic rule closes my open document. I just can't find  this option or else I misundersstand this solution.
Message 5 of 10
Mark.Lancaster
@JorisSteurs1246
THis posting is 2 years old and the contact you are using may no longer be monitoring this forum.  I would recommend creating a new posting...
Mark Lancaster
Message 6 of 10
U can use the rule as button...and u should set action as shown in the above image Post...in the rule....u can do some operation like ilogicForm.show or run any codes....editor has the option for click behavior....
Message 7 of 10
Hi
In my form builder (Inventor 2016), the above options are not showed.
All I can choos under behavior is the name of the parameter to activate/desactivates this button.
Is this a version problem?
Message 8 of 10
johnsonshiue
Hi! I could be wrong but the option is only available if you have a rule and you are trying to define a new form. If you select the rule in the form dialog, you will see the option in the panel at the bottom.
Many thanks!
Software Test Engineer
Message 9 of 10
Hi, thanks for your answer.
I tried it again and found out, that these options are only available for document rules but not for global rules.
Anyways, I found a solution for the problem here:
https://forums.autodesk.com/t5/inventor-customization/ilogic-forms-why-no-quot-on-click-action-quot-...
Message 10 of 10
Yijiang.Cai
This has been implemented within Autodesk Inventor 2024. Please review the Inventor 2024 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Thanks!
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
