Is it possible to make an iLogic if statement that can tell the difference between parts and assemblies? I want to add iLogic to our (part and assembly) templates so that when placed in the drawing level the parts list description will be different. I know that this is not the proper way to do it and there are better ways but I need to know if this way is possible. I would appreciate any help that you could give.
Example:
At assembly level I want the description (custom I property: Description 1) to populate the parts list.
At part level I want the description (custom I property: Description 2) to populate the parts list.
JD
Solved by MechMachineMan. Go to Solution.
Solved by cwhetten. Go to Solution.
The following should get you rolling:
DocType = ThisDoc.Document.DocumentType If DocType = DocumentTypeEnum.kAssemblyDocumentObject Then 'it's an assembly file Else If DocType = DocumentTypeEnum.kPartDocumentObject Then 'it's a part file Else If DocType = DocumentTypeEnum.kDrawingDocumentObject Then 'it's a drawing file End If
Cameron Whetten
Inventor 2016
Alternatively:
Select Case ThisDoc.Document.DocumentType Case DocumentTypeEnum.kAssemblyDocumentObject 'it's an assembly file Case DocumentTypeEnum.kPartDocumentObject 'it's a part file Case DocumentTypeEnum.kDrawingDocumentObject 'it's a drawing file Case Else End Select OR: Select Case True Case ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject 'it's an assembly file Case ThisDoc.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject 'it's a part file Case ThisDoc.Document.DocumentType =DocumentTypeEnum.kDrawingDocumentObject 'it's a drawing file Case Else End Select
