iLogic rule
iLogic rule
Dopey1993
iLogic rule
Dopey1993
THIS RULE WORK WELL ON A IAM FILE HOW DO I GET IT TO WORK ON A IPT FILE
SyntaxEditor Code Snippet
Sub Main
    If TypeOf ThisDoc.Document Is DrawingDocument Then
        Dim dwgDoc as DrawingDocument = ThisDoc.Document
        For Each dwgSheet As Sheet In dwgDoc.Sheets
            If dwgSheet.DrawingViews.Count > 0 Then
                modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName
                modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
                prtNumber = modelDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value & " - " & _
                    modelDoc.PropertySets("Design Tracking Properties").Item("Description").Value
                If Not String.IsNullOrEmpty(prtNumber) Then
                    dwgSheet.Name = prtNumber
        Next
End Sub
Mark.Lancaster
I'm confused...   You rule looks like it runs on a drawing not an Inventor assembly.
Mark Lancaster
Dopey1993
YES I HAVE THE RULE WRITTEN IN A IDW FILE
IT WILL READ THE PART NUMBER AND DESCRIPTION OF A IAM FILE BUT NOT A IPT FILE
