Message 1 of 1
Ilogic replace components
04:54 AM
I want to replace a part in my assembly. That works fine with the component.replace function when I just write the code in an empty form.
But I have another form which opens an assembly and replaces a component. Then it does a save as function and it closes.
On this code the component.replace function doesn't work. Does anybody knows why it isn't working?
sorry for the bad english
SyntaxEditor Code Snippet
AssemDoc = ThisApplication.Documents.Open(Partlocatie) oDoc = ThisApplication.activedocument 'Hier wordt het level of detail aangepast zodat alleen de gewenste configuratie zichtbaar wordt. oDoc.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("LevelofDetail1").Activate Parameter.Quiet = True 'Een aantal regels die variabelen definieren om daarna parameters uit te kunnen lezen. Dim oOpenAssemDoc As Inventor.AssemblyDocument oOpenAssemDoc = ThisApplication.ActiveDocument oParams = oOpenAssemDoc.ComponentDefinition.Parameters oUserParams = oParams.UserParameters 'Hier worden alle mogelijke parameters aangepast, de waardes die achter de variabele staan zijn er om een variatie te verbergen. oUserParams.Item("Lengte").Value = Lengte/10 oUserParams.Item("Breedte").Value = Breedte/10 oUserParams.Item("Hoogte").Value = Hoogte/10 oUserParams.Item("Aandrijving").Value = Aandrijving oUserParams.Item("Motorzijde").Value = Motorzijde oUserParams.Item("Poot_Positie").Value = Pootpositie Bandlocatie = "J:\Engineering\Stage\Koen Clemens\Test Factory design suite\Parametriche modellen\10160 B2 Frame" + Teller & ".ipt" MessageBox.Show(Bandlocatie, "Ilogic") 'Het document wordt geupdated, opgeslagen en gesloten Component.Replace("10160 B2 Frame", Bandlocatie, False) Parameter.UpdateAfterChange = True iLogicVb.UpdateWhenDone = True oDoc.SaveAs(StrFolder + "\" + partnaam + "(" + Teller + ")" & (".iam"), True) oDoc.Close(True)
