Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ilogic partnumber change in assembly and mass unit change
1 REPLY 1
toon.gielen
453 Views, 1 Reply
Hi all.
I've got an assembly with parts. I need to change the PN of each part to be the same as the filename as well as the unit of mass should be kg instead of lbppounds.
I managed to change globally the lbpounds of the parts to kg. The bom was also updated.
But I need to add a rule in order this change is permanent. (I use the parts in other projects).
With the rule (under) : it works only once. When I reopen the assembly with all the parts, the unit is again lb pounds.
Specific question. I need to have the kg unit for each part. Permanently stored in the properties of the individual part. as well as the partnumber should be the filename. For the partnumber change for each part, I tried a code but it doesnt work. Any suggestions please?
code for mass unit change. (only works for the assembly bom, I need to have it work for each part permanently)
SyntaxEditor Code Snippet
'get input from user
oUnit = InputRadioBox("Select a unit of measure type", "Metric", "Imperial", False, "ilogic")
If oUnit = True Then
'set to millimeter
oUOM_1 = UnitsTypeEnum.kMillimeterLengthUnits
'set to kilogram
oUOM_2 = UnitsTypeEnum.kKilogramMassUnits
Else
'set to inch
oUOM_1 = UnitsTypeEnum.kInchLengthUnits
'set to pounds mass
oUOM_2 = UnitsTypeEnum.kLbMassMassUnits
End If
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
    'look at only part files
     If docFile.DocumentType = kPartDocumentObject Then
     'set mass units
    docFile.unitsofmeasure.MassUnits = oUOM_2
    'rebuild to update the display
    docFile.Rebuild
    End If
Next
iLogicVb.UpdateWhenDone = True
Thank you for helping me.
 The fault code for the partnumber change
     'set mass units
     'set partnumber
      docfile.iProperties.Value("Project", "Part Number")=docfile.FileName(False)
    docFile.Rebuild
    End If
Next
1 REPLY 1
@toon.gielen,
To retain part number and mass unit change, saving the document (docFile.Save()) would be helpful.
Can you please provide sample Inventor files to investigate? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
