iLogic measure angle between selected faces
I've been developing a rule that works very well except for one part.  I dont know the proper syntax to measure an angle between selected faces using iLogic.  The Measure.Angle command seems to be looking for string values (ex. a work plane's name).  Does anyone know the proper syntax so I can have the rule check if the planes intersect?
I know using the measure tool is much simpler, but this is an example from a section of a more extensive rule i'm developing.
SyntaxEditor Code Snippet
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPlane1 As Face
oPlane1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities,"Select the face of the part")
Dim oPlane2 As Face
oPlane2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities,"Select an intersecting plane")
oMeasure = Measure.Angle(oPlane1,oPlane2)
If oMeasure = 0 Or 180 Then
MessageBox.Show("Selected planes do not intersect. Please select intersecting planes.","iLogic")
Return
Answered my own question...  The Measure function in ilogic seems to only work with work features.  Planes must be created, constrained to the faces, then the measure function searches for those planes' names to measure between. Here is code for measuring between two faces.
oFace1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities,"Select Plane1")
oFace2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities,"Select Plane2")
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Try
	oAsmCompDef.WorkPlanes.Item("iLogic_Proxy_Plane1").Delete
	oAsmCompDef.WorkPlanes.Item("iLogic_Proxy_Plane2").Delete
Catch
	'Do nothing
End Try
oPlane1 = oAsmCompDef.WorkPlanes.AddFixed(oTG.CreatePoint(0,0,0),oTG.CreateUnitVector(1,0,0),oTG.CreateUnitVector(0,1,0),False)
oPlane1.Name = "iLogic_Proxy_Plane1"
oPlane2 = oAsmCompDef.WorkPlanes.AddFixed(oTG.CreatePoint(0,0,0),oTG.CreateUnitVector(1,0,0),oTG.CreateUnitVector(0,1,0),False)
oPlane2.Name = "iLogic_Proxy_Plane2"
oAsmCompDef.Constraints.AddFlushConstraint(oPlane1,oFace1,0)
oAsmCompDef.Constraints.AddFlushConstraint(oPlane2,oFace2,0)
oDistance = Measure.MinimumDistance(oPlane1.Name,oPlane2.Name)
MessageBox.Show(oDistance, "iLogic")
