iLogic fun - Changing an iProperty in each part of an assembly
Here is my code to cycle through each unique instance of a part in an assembly.  My goal is to change the "Category" field in the "Summary" section of iProperties to "Custom."  I'm doing this to streamline an annoyance with loading new assemblies and parts into Vault.
' Get the active assembly document.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
' Verify that the document is a part.
If oDoc.DocumentType = kPartDocumentObject Then
Dim oPartDoc As PartDocument = oDoc
'Manipulate part
Dim fileName As String = ThisDoc.FileName
Dim model As String = fileName & ".ipt"
'iProperties.Value(oPartDoc,"Summary", "Category") = "Custom"
iProperties.Value(model,"Summary", "Category") = "Custom"
End If
Next
The issue is after 'Manipulate part.  I'm not sure what the proper code is to access the iProperty of the referenced part.
Any help is appreciated!  Thanks.
Brian Daley...
tschaeferZNBXX
So are you creating a "Custom" iProperty? I am confused as to what you are really trying to do here.
I have some code that can show you how to set iProperties.Values to Custom iProperties.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Sorry if I was unclear there.  No, we either have "Stock" parts or "Custom" parts.  If I touch it then it's a custom part so I'd like to be able to turn all the "Category" iProperties in an assembly to say Custom at the click of a button.
I hope that clears it up a bit.
Curtis_Waguespack
Hi briandaley,
I think you'll need to look at the part's component occurence in addition to the document, here's a working example:
http://forums.autodesk.com/t5/inventor-customization/ilogic-to-change-iproperty/m-p/6030730#M61562
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
karthur1
I don't understand if you want to change ALL of the parts in the assembly or just the selected ones?
All that garbage code drives me nuts.  I figured it out on my own.  All I needed was the DisplayName function in PartDocument.
This code cycles through each unique part and changes the Category to Custom if the field is blank.  If the part is not in the current folder then a message pops up saying that it needs to be done manually on that particular part.  It wouldn't be hard to change that either with FullFileName but then there will be some redundant code and I'll save making a new sub for tomorrow.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
'Manipulate part
        Dim model As String = oPartDoc.DisplayName
        model = model & ".ipt"
        Try
            If iProperties.Value(model,"Summary", "Category") = "" Then
                Else
            End If
        Catch
        MessageBox.Show("Must manually change " & model)
        End Try
    End If
Next
No garbage code to make it look fancy and it works with subassemblies as long as all the parts are in the same folder.
Hi There and Thank you for the code,
I'd like to add that the model file name includes already it's extension therefor no need to add it.
Here is the working code, I commented out that part
'Manipulate part
        'model = model & ".ipt"
        Try
                Else
            End If
        Catch
        End Try
    End If
Next
