iLogic error - IV2015
Scott_Stubbington
Scott_Stubbington
I am by no means an iLogic expert so if there is anyting wrong with the code feel free to point it out. Smiley Happy
I have written a small piece of code(iLogicCode.jpg) for an assembly animation.  When I close the editor I am given an error as shown in iLogicError.jpg, but the error changes to suit the value of parameter d2, if d2 = 0 then the error will read "Parameter: Could not find parameter named: "0"".
Is this iLogic inexperience on my behalf or........
Thanks in advance for your help.
Scott Smiley Happy
BrandonBG
Instead of using
Parameter(d18)
try
Parameter("d18")
or just
d18
BrandonBG
Inventor 2015
ASchlaack
If the d18 parameter is inside of the .iam you're working in then it should just read "d18". However if it's a parameter from a different .ipt it should be displayed like the attached picture where the first part is the file name and the second is the parameter name.
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
