iLogic - Creating STL with options
This widget could not be displayed.
I created a iLogic routine to generate a STL file if the iProperty "Printed Part" is set to YES.
I am getting an error when Ln33 oTranslator.SaveCopyAs(oDocument, oContext, oOptions, oData) is executed.
Any help would be appriciated
If iProperties.Value("Custom", "Printed Part") = False Then 'False = "NO"
	Return
Else
	MsgBox ("Selected to output STL for printing" & vbCrLf & "Disable by setting the custom iProperty:Printed Part to NO")
'Create _OUTPUTS directory
oPath = ThisDoc.Path
oFolder = oPath & "\" & iProperties.Value("Custom", "Output Directory")
'Check for the custom iProperty directory and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
' Get the STL translator Add-In.
Dim oTranslator As TranslatorAddIn
oTranslator = ThisApplication.ApplicationAddIns.ItemById ("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'Configure options and write out
If oTranslator.HasSaveCopyAsOptions (ThisApplication.ActiveDocument, oContext, oOptions) Then
	oOptions.Value("ExportUnits") = 1	'Inch	'Based off of index in combo box in STL Export Dialog
	oOptions.Value("Resolution") = 1	'High	'Based off of index of radio buttons in STL Export Dialog
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    Dim oFileName As String
	oFileName = ThisDoc.PathAndFileName(False)
	oData.FileName =  oFolder & "\" & oFileName & " Rev " & oRevNum  & ".stl" '
	'Write out file
Else
	MsgBox("!!!ERROR: STL File was not created!!!")
Replies (7)
I did find one code error, but did not fix my issue
Ln30 should be:
oFileName = ThisDoc.FileName(False)
mrattray
You'll likely get a better response to programming questions on the Inventor Customization forum. This is where all of the developer types hang around.
Mike (not Matt) Rattray
Old post, but did you found out waht your error was+
im interested to use this code also.
Best regards
Lennart
t_hascj
Hi Lennart,
oDocument is uninitialized.
Jaroslav
Sorry, but i dont understand?
Is there a code that works.
Lennart
t_hascj
You ask about solution for code in the first post. You need to initialized the oDocument.
oDocument = ThisApplication.ActiveDocument ' add this code
Here is another code https://forums.autodesk.com/t5/inventor-forum/ilogic-save-as-stl-in-mm-with-high-quality/m-p/7287161...
Thanks.
Aha ok i got it.
Thanks man.
